WMFUG742PUK pressure switch reset or software
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries WMFUG742PUK pressure switch reset or software
  • #87919
    Rograbbit
    Hi folks. Model WMFUG 742 P UK s/n 412197263 ind code 30862480195. Removed sock from sump hose. Carried out a couple of pressure switch resets. It now drains for a long time. No fill. Drum rotates as if washing on quick wash not on other programmes. Have I got to keep trying p switch reset or is this one with dodgy software that has to be reprogrammed? Didn’t look to see if Arcadia board. Thanks
    #436428
    Rograbbit
    Re: WMFUG742PUK pressure switch reset or software
    By the way. Forgot to say I did try it after removing sock before resetting p switch.
    #436429
    AMS
    I’ve got a WMPF843G UK doing the same thing. How do you do a pressure switch reset? Sorry can’t help you with your snag. I was going to give EMW a call tomorrow morning.
    have you looked at the top of this forum ??
    hotpoint-indesit-pressure-switch-reset-t69601.html
    AMS
    Thanks for that.
    #436432
    Rograbbit
    Hope you’ve got the reset procedure. I know a lot have to complete several times for it to work. My customers machine was working ok before blockage so I suppose a few more attempts is in order.
    #436433
    Rograbbit
    Update. Got the customer last night to leave the machine on a programme. He said it did hardly anything for around 20 mins then started filling. He has now done 3 washes no problem. So something learned just need to wait a little longer.
