WML520p 65125906040078
  • #72970
    ChrisR
    Problem with door seal on this Hotpoint.
    The rubber section that fits into the recess in the outer tub seems to big on the new seal and wont fit
    Ordered hotpoint alternative but thats the same as well
    Any suggestions.
    Thanks.
    Chris
    #386110
    AJC_Dave
    Re: WML520p 65125906040078
    There’s 2 different seals fitted to these. The WF type one and a flimsy one that’s a bit cheaper. The other should come up in the search but will have a look for you..
    AJC_Dave
    Try C00111416.
    ChrisR
    C00111416 is the same as the connect one
    Gsk9372 which won’t fit
    #386113
    AJC_Dave
    Other than a WF (GK9197 from Connect)one, Im not aware of any others that are used on these.
    Sorry I can’t be of more help.
    ChrisR
    You’ve been a great help Dave
    Many thanks
    #386115
    johnnyj
    I think you need C00143605 as the comercial code 65125 makes a North wales made machine
    #386116
    ChrisR
    Thanks for all the advice
    Chris
