I had one on the van so didn’t look through codes to be honest.She didn’t mention that she moved it on just that it took over 2 hours for a 30 degree wash.
Oh well,cheers BG
seems a much more common failure on the hotpoints now
wonder why?
i did have one that consistently blew heaters turned out the front half of the drum was from a washer dryer but as this was a washer there was a difference in the soap disp hose so the machine would not fill correctly
i wonder if the heater failure is a result of lower water levels?
These machines certainly don’t use much water in a wash,as the drum is turning and creating air pockets in the water there could be a fair amount of the element ecposed at times perhaps,excellent,food for thought DDSDDS !
BG
