Hi guys the above washing machine, lets you select program and press start then it sits dormant for a few mins then the door lock light stays on (red) and the one just above it comes on also (green).
The motor is brushless, from reading the fault codes I should be looking at the ntc or pcb? Does that sound right?
Anyone come across this before?
Thanks in advance.
