WMM39A Wiring help please
  • #37904
    arosview
    Could anyone help with a motor to module wiring sketch, 4 wires have snapped. I really need to keep this machine going with butt connectors until I can get a new harness. (incontinent disabled person).
    Could anyone also please confirm the part no. from an earlier post I noted that Jim IADOM mentioned C00201351 but when I put this into Qualtex the description comes up as Harness-valves/pump.
    Cheers David
    #257034
    hotpnt
    Re: WMM39A Wiring help please
    HI, from the motor plug at the module, there is a 10 wire plug to motor & interlock, 1st 3 wires go to interlock, then no4 goes to motor plug no1 (tacho), then in order (module goes from 4 – 10, in sequence with motor plug from 1 – 7,) so that the last one on the module is no7 on motor,
    harness from module to motor/interlock is C00201352
    hth
    #257035
    Found the thread and corrected my boob.
    Sorry for any inconvenience caused.
    Have e-mailed you a wiring diagram, it should help.
