wont pump in but seems to pump out
Home Forums Public Support Forums Help And Support Dishwasher Help Forum wont pump in but seems to pump out
  • #51192
    moffy
    Hi Guys,
    I’ve got an AEG OKO favorit 5040. Pretty old but solid. Its just stopped mid cycle with water in it.
    Opened the door and turned the switch round again…it pumped the old water out. I poured some more in by hand and it also pumped that out.
    However when I try to start the cycle again the water is not coming in.
    Any ideas what could be wrong please, wether a competent DIYer could fix it and how much any spares required might cost, roughly.
    Happy new year to all who help on these forums and thanks for being there!!!
    Moffy
    #307199
    TheSpinDoctor
    Re: wont pump in but seems to pump out
    Hi.
    I assume that the drain pump is not running constantly. If so, you have a leak inside the machine. If not, check tap is turned on, inlet hose is not kinked or blocked & inlet valve coil is not open circuit.
    #307200
    moffy
    Thanks a lot, I will check those things.
    Regards
    Moffy
