I Tried to Get response from one of you But did not Get a reply I Have Two WFF 2001 Washing Machines One of which I Had for a long time The Brushes were suspected to be the Fault for it not working and that proved to be the Case where it worked Just Perfectly as New But After six weeks or so the Machine was to Break down: The Machine works on The Spin Drying Cycle but Ceases to work on the wash Cycle: Thinking that I could Get some spare Parts from off the same Model of which I Bought I Plumbed and Plugged the Machine in only to find that this too had the Exact Problem Both Machines Start up on the Dry Cycle when I select the Spin Dry Cycle where Both Drums Spin Just fine without any Noise coming from the Bearings: I was wondering if the Circuit Board on both Machines were at Fault If that’s the Case I am willing to spend that Extra Pound to get one or both of them working: They Being Both hot and Cold Fill Makes Me want to Keep them because I Can wash the Clothes on a shorter Cycle Please someone that has Brains solve the Problem for me without having to pay £114 for a Home visit from an Engineer ❓ 😥 ❓ ❓
No I have not checked the Heater But surly if that was the Problem ! would the Faulty Heater Have Blown a Main Fuse But I will check it out Nevertheless and Take the Heater out and put a test on it I’ll Try anything to get the Machine working as Bosch is a Quality Machine Company But if its Not that have you any other suggestions
