Would loose screw cause oven mode malfunction?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Would loose screw cause oven mode malfunction?
  • #102125
    Neil_P_South
    My oven was sometimes (but not always!) failing to get to temp on some modes. When I came to fit a new switch (the elements tested ok with a multi meter), i noticed that one of the screws was loose where the power cable is attached. Could a loose connection cause the symptoms I experienced? I have replaced the switch now anyway (that was like open heart surgery crossed with diffusing a bomb!)
    #487644
    matrixresonator
    Yes, If you look where the live wire goes in there’s a jumper to that terminal with the loose screw. If it’s failing to connect there, then whatever that connects to isn’t getting a live supply.
    #487645
    Neil_P_South
    matrixresonator wrote:Yes, If you look where the live wire goes in there’s a jumper to that terminal with the loose screw. If it’s failing to connect there, then whatever that connects to isn’t getting a live supply.
    Grrr …. wish I had spotted that the first time around! Oh well a new switch installed, and everything tightened. Ho hum we live and learn 🙂
    #487646
    Marsha2007
    I had almost the same problem and thank you for your post because with your help, I solved my problem as well.
