Hi. Dont usually look at many Whirlpool dishwashers. This one the customer says was sticking on rinses and bleeping, would empty ok. Now its completely dead, she did say it tripped the electric once. Do these have door wiring problems?, or should I be looking elsewhere?
Just got back in touch with customer on this one. She had a handy friend look at it. Turned out be pressure switch blockage, together with a trailing socket fault, which is why it went dead! Heres me thinking earth fault due to component failure, which then took the board. You never can tell till you go and have a look can you? :rolls:
