WPL Tumble Dryer (857534115031) PCB not responding, power into appliance to the pcb but not lighting up, checked over all other components seem ok, looks like a pcb fault any one had this fault.
don’t know if this helps at all. about last year i went to a t.d. not starting or lighting up. it turned out that behind the start button cover there is a hinged plastic part of the p.c.b. housing which is meant to press against the on-board tactile switch. well this plastic bit had fallen of (plastic fatigue) on so the button cover was unable to reach.
