WPL D/w No heat Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › WPL D/w No heat This topic has 3 replies, 2 voices, and was last updated 16 years, 2 months ago by Steven. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts February 8, 2010 at 11:29 am #52325 StevenParticipant Hi guys Wpl 854241615810 DWFB10w Not heating appears no supply to heater. It fills ok, pressure flow switch replaced because it had a pin hole, thought that was it. Have checked all the obvious, heater ,stat broken wires but still no heating? 😳 Had s/h pcb which knew was ok it so fitted it still not heating? Goes through the cycle open dispenser (so should heat just after) no fault codes coming up? Any ideas please 😕 😕 February 8, 2010 at 4:17 pm #311366 spanner51Participant Re: WPL D/w No heat If it goes through the cycle without heating, it’s the NTC. I have fitted the beko one’s at a fraction of the price, and it works OK for me graham February 8, 2010 at 4:47 pm #311367 StevenParticipant Re: WPL D/w No heat Cheers Got Part Number for the Beko one? February 8, 2010 at 6:56 pm #311368 spanner51Participant Re: WPL D/w No heat The Connect bar code number is 5031680625271 or here http://www.4beko.co.uk/cgi-bin/product. … =&part=ntc Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
