Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › WPL K40 ice machine
- This topic has 9 replies, 2 voices, and was last updated 19 years, 3 months ago by
abbots.
December 15, 2006 at 1:02 pm #23391
abbots
Participanthi guys,
any experts on the WPL ice machines out there?there appears to be a refrigerant leak some where,we have to keep topping the refrigerant level up regulary, no exposed pipework seems to be leaking on the high pressure side, pipes to and from commpressor seem ok,are there any common places for leaks to appear. does the evaporator ever produce leaks?
i’ve seen a few accumulators leak over the years on this model but this seems fine.
any ideas?
johnDecember 15, 2006 at 1:44 pm #197966welsh__boy
ParticipantRe: WPL K40 ice machine
Underneath the freezing plate in the middle. Had 2-3 in the last couple of years, not exactly common but worth a look.
December 15, 2006 at 2:58 pm #197967abbots
thanks mate,
did you repair them or did you replace the evaporator plate complete?
jkDecember 15, 2006 at 4:43 pm #197968welsh__boy
We just replaced them, far easier, they normally start leaking in the most awkward of places so far easier just to replace. More expensive repair but you save a lot of time and you then know for sure that’s it’s done properly.
December 15, 2006 at 5:01 pm #197969abbots
sounds like good advise. dont suppose you have a part number and reliable supplier do you.
jkDecember 15, 2006 at 6:51 pm #197970welsh__boy
ACME refrigeration 01254 277955, can’t think of the part number right now, but when I’m back in on Monday I’ll look at the diagrams for you. They should be able to work it out for you just by the description.
December 16, 2006 at 8:12 am #197971abbots
thanks,
a part number would be great.
jkDecember 18, 2006 at 1:31 pm #197972welsh__boy
Sorry it took so long, got the part numbers for the K20 first, different for the K40!!
ACME 01254 277955 fax 01254 277988
P.No C1-481231038713
£155 list
£12 P&P in stockIce Machines UK 01483 205749 fax 01483 205748
P.No 33ca
£165 list
£10 P&P 1 in stockAll depends on what sort of discount you’re offered for trade, you should get a better deal with IceMachines UK.
December 18, 2006 at 1:53 pm #197973welsh__boy
I’d better add, but I’m sure you’re fully aware of this, that you’d better be sure it is the evaporator assembly before changing it as it’s quite an expensive repair.
Chris
December 18, 2006 at 3:12 pm #197974abbots
thanks for the help chris,much appreciated.
john
