wpl td no heat
  • #19308
    abbots
    hi guys,
    has anyone got a wiring diagram for a
    AWZ220
    857522015000
    no heat.element ok,inlet stats ok,exhaust stat ok, timer replaced ?
    thanks.
    john
    #182591
    Re: wpl td no heat
    abbots wrote:has anyone got a wiring diagram for a
    AWZ220
    Check your emails John 😉
    #182592
    abbots
    Re: wpl td no heat
    cheers martin.
    john
    #182593
    bzz67
    Re: wpl td no heat
    I SEEM TO REMEMBER HAVING THIS FAULT BEFORE.IF YOU HAVE ONLY METER TESTED THE ELEMENT, TRY REPLACING IT OR PUT MAINS DIRECTLY TO IT.BROKEN ELEMENT CAN STILL SHOW A RESISTANCE ON A METER.
    #182594
    abbots
    Re: wpl td no heat
    thanks guys,
    i’ve been out and sorted it,the exhaust stat was testing fine on the meter but breaking down under load and going open circuit.
    jk
    #182595
    bzz67
    Re: wpl td no heat
    WELL DONE, NICE TO HAVE A CHALLENGE OCCASIONALLY.
