Re: W’pool ADG7540/1
Thanks for that John…
A little history to this one….the original fault was a no heat fault although the machine completed the cycle and gave no error reading so I took the belt and braces approach to replace both the ntc and then the pcb. The replacement pcb has slightly different orientation to the edge connectors including an additional space for an OWI connector. The new board immediately gives an E11 error on power-up (this fault not present on the original board)
So….i suspect the model/service number may be incorrect so any advice about similar models that may have the same pcb would be welcome…or indeed if anyone has the contact number of a techie within W’pool that may have an answer?
