wpool adp7540 top spray arm
  • #53340
    deltra
    hi, top spray arm doesnt turn,it is clear but water just trickles out ❗ bottom arm seems fine ❗
    #315461
    chezza
    Re: wpool adp7540 top spray arm
    Check the rubber seals arent perished where the spout of the spray arm on the upper baskets marries in to the feed tube for it – also check the 2 spouts at the base of the feed pipe haven’t come loose from their clips ( where they push in at the filter area )
    #315462
    deltra
    cheers, checked and they seem fine ❗
    #315463
    Got an ASKOLL MOTOR in it?
