Re: w’pool awo3961 leak by dispenser
Have you cleaned the valve grit traps? Also the venturis inside the dispenser lid – take the fill hoses off the dispenser and push a small Allen key into the nozzle and turn it around. That should break up any scale that has formed around the inside of the nozzle. Replace hoses and test. Slow water fill (especially on hot) can cause the water to trace across the dispenser lid and leak.
If not, looks like the dispenser is at fault…….
Steve.
