W’Pool Dryer AWZ8578 need error codes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries W’Pool Dryer AWZ8578 need error codes
  • #61153
    myfil
    I went to a W’Pool Condenser Dryer Model AWZ8578 (8575 8571 5080), on starting any pgm it would pause then flash the following red LEDs continuously (and not start)
    Clean filter
    Empty Bottle
    Clean heat exchanger
    PLUS the four green LEDs along the top are constantly lit
    All the above items were checked, but still got the same error code and no start.
    Can anyone help with error codes for W’Pool dryers (none not in the WGoods book)
    Any suggestions re this particular code?
    #345036
    myfil
    Re: W’Pool Dryer AWZ8578 need error codes
    Has anyone had any experience with the “three flashing red LED” problem with W’pool dryers? I notice there are many reports of this problem on the general internet, with no workable solutions mentioned anywhere.
    There’s a thread from 2008 on WG, titled “whirlpool awz 7913”, but no remedy there.
    Any suggestions/fault codes folks? Or is this just a PCB failure?
    #345037
    chezza
    you have e mail mike
    eddie
    #345038
    daisbiz
    hi fault code for ur awz8578 is Disturbance in the humidity sensor system or failure of the default setting values ntc.
    potential causes-check humidity sensor and or electrical connectors.
    check humidity module function and or electrical connectors.
    To carry out a reset procedure the following sequence must be performed within 10 seconds.
    1 turn selector in the 6 oclock position ( DOWN )
    2 push the start button 3 times
    3 turn the selector clockwise 1 position airing program
    4 push start button 3 times,this should reset timer.
    maybe try reset 1st.hope it helps. 🙂
