wpool dw f4 & f6
  • #29569
    cab
    hi, been out to a dishwasher ADP5966 for an F4 fault, it had drained ok, I took off the pump and checked for blockages, none. When I put it back onto a rinse it aborted after a few minutes washing with F6. Is it likely the optical sensor is at fault?
    thanks
    cab :bounce:
    #223657
    DentedPorsche
    Re: wpool dw f4 & f6
    f4, check the black grid under the filters, make sure it’s not clogged with crud.
    f6, flow meter, unplug it, clean and tighten the plug and put it back on. works 99.9{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time.
    Brian
    #223658
    cab
    thanks for that
    cab
