WT46W560 GB/01 Not Drying. Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › WT46W560 GB/01 Not Drying. This topic has 4 replies, 2 voices, and was last updated 12 years, 4 months ago by Turbo. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts December 7, 2013 at 6:44 pm #78503 TurboParticipant Hi Customer complaining that sometimes the sensor dry programs leave the washing far too damp. Happens about once in 7 loads. Any suggestions. Thanks Graham December 7, 2013 at 7:32 pm #405905 MartinParticipant Re: WT46W560 GB/01 Not Drying. Heat pump Siemens is it? You’ve gotta hope it is an NTC problem as your best option. 🙁 December 7, 2013 at 8:15 pm #405906 TurboParticipant Re: WT46W560 GB/01 Not Drying. Correct it has the heat pump Martin. How does this model measure the damp in the clothes? December 7, 2013 at 10:21 pm #405907 MartinParticipant Re: WT46W560 GB/01 Not Drying. Turbo wrote:How does this model measure the damp in the clothes? IIRC there’s an NTC located on the capillary tube that measures the heat level from the drum air outlet. February 26, 2014 at 6:01 pm #405908 TurboParticipant Re: WT46W560 GB/01 Not Drying. Does anyone know how you change the thermistor at the front of the dryer, do you have to take the front panel off or can you remove the right hand fan cover for access? Thanks Graham Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
