WTA200 Not Spinning
  • #28566
    dmthompson
    I’ve got a Bosch WTA200 Spin Dryer that isn’t spinning.
    Could it be the brushes?
    How do I get them out to check.
    Any help appreciated.
    #218933
    Re: WTA200 Not Spinning
    WTA2000 is a tumble dryer if I recall correctly. It uses an induction motor, so no brushes.
    If you can hear the motor runnng, the drive belt will have failed. If you can’t hear the motor running it’s most likely that the motor start/run capacitor has failed.
    Power off, if investigating.
    Ritch
    does the drum turn on a wash programe and then not spin or does the drum not rotate at all even during a wash cycle?
    #218935
    TUMBLE DRYER………
    :p45:
    #218936
    helo_75
    louder please, im not sure theyre gettin the message
    hi p45
    #218937
    Ritch
    sorry couple of beers long day best leave this to the awake engineers
    #218938
    gegsy
    Full model number aswell please – WTA2000GB/01 or WTA2000GB/17.
