Bosch dryer cutting out on auto before clothes are dry,had a look at brush arm onto drum which looked OK.
bWhat should I be looking at specifically for this fault.
Cheers
BG
The ‘anti-crease’ led flashing indicates a possible prob with the rear NTC which could be a no heating fault maybe ?
Unless it’s the ‘end’ part of the led in which case i’d be looking to clean the sensor paddles in the drum and making sure there is a good big load in the drum as these machine sdon’t like small loads or items .
