WTE6920gb/04
  • #39169
    timdowning
    FD841120062
    Not seen dryer yet but want to be armed with some info.
    Customers says dryer is beeping and the filter light is staying on.
    Any advise will be warmly accepted.
    Any tech info available??
    #261516
    Re: WTE6920gb/04
    The usual…..pump hose to water tank blocked I expect. 😉
    #261517
    timdowning
    Re: WTE6920gb/04
    Been to see dryer earlier today. (Tested with full wet load).
    Actual fault: dryer selects as normal and turns on as normal.
    After 2/3 minutes the dryer beeps intermittantly, the ‘time to go’ display drops to 8 minutes and drum rotation continues. The filter light comes on as well. ( If I left the dryer running it looks like it would countdown from eight to zero).
    I checked for blockages, all ok. I’m getting a circuit through both elements. Pickups on the drum cleaned and continuity checked to connector on PCB.
    Anyone had this fault before? Some technical data would be appreciated.
    Many thanks.
    #261518
    Re: WTE6920gb/04
    8 mins to go means it has gone into default cool down so I would suspect the temp control NTC in the front duct is playing up or the air flow around it compromised maybe?
    You can check the NTC value directly off its plug-in connector on the main module. 😉
    #261519
    timdowning
    Re: WTE6920gb/04
    Cheers Martin.
    Do you have any values to hand for the NTC?
    #261520
    Re: WTE6920gb/04
    Sorry mate no! 🙁
    Give Greg an email for that 😉
    #261521
    gegsy
    Re: WTE6920gb/04
    Info in the ether as I type 😉
