is it the drying and iron drying leds ? If yes , then thats a ‘condensation container full’ fault……so i’d be looking at the pump , sump or drain hose between the pump and container .
These appliances do have a habit of gunging up in the pump sump area , especially if the customer doesn’t clean the condensor regularly. Pumps on the LHS as you look at the machine. To access , remove left hand side panel…..not forgetting the 2 screws behind the control panel that help secure the side panel.
