The heater reset stat was ok, continuity reading ok on the three heater terminal pins, also had a resistance reading on the sensor next to the reset stat. Did not check the sensor at the front of the dryer do these give trouble? This dryer looks like new, had very little use, not sure of age.
The FD number is 8501200087
Would be glad of some advice thanks.
Turbo.
