WTL6102gb02 No Heat
  • #43300
    Broadband
    Dryer runs for a few secs with no heat stops runs again then stops the drying light is on then the anti crease/end light comes on and it continues to do this with no heat. I think it must be a sensor, only problem is, they are a bit expensive if I’m wrong.
    Has anybody come across this?
    #276782
    Washman
    Re: WTL6102gb02 No Heat
    You need to test these with a damp load , will not run for long if no load.
    Mike
    #276783
    What washman says plus press red button on overheat stat. 😉
