WVD24460gb/02
  • #73557
    dave-m
    Howdy,
    Going to look at this tomorrow, it apparently washes and empties but fails to spin.
    They reckon it’s not much more than two years old.
    I’ve not had the pleasure of this model before, any known problems?
    Cheers
    suedehead1
    Re: WVD24460gb/02
    out of balance load?
    #387910
    dave-m
    Re: WVD24460gb/02
    It may be an out of balance load, or I’m hoping that there’s a little ‘coin operated butterfly valve’ and it’s not actually emptying all the time.
    #387911
    jason1970
    Re: WVD24460gb/02
    out of balance load. What was the customer washing?
    #387912
    Re: WVD24460gb/02
    Pump or or brushes or both!
    #387913
    dave-m
    Re: WVD24460gb/02
    I’ll make sure I have both when I call Martin, cheers.
    #387914
    dave-m
    Re: WVD24460gb/02
    Update.
    Called to this today and sure enough it’s not spinning.
    I had stuck in a pump just in case it was failing intermittently, but it empties fine and then just sits there (showing 11 mins left on the ‘super quick’ wash) but you can turn it off and select the spin and it spins ok.
    I meggered the heaters and the motor and all are good. The board looks fine and the m/c is only just over two years old.
    It’s beginning to look like the board is goosed!
    Has anyone any other ideas?
    Cheers
    Re: WVD24460gb/02
    dave-m wrote:(showing 11 mins left on the ‘super quick’ wash) but you can turn it off and select the spin and it spins ok.
    Super Quick wash has only a short spin so does it spin at all on that cycle? And does the 11 mins not count down anyway?
    #387916
    dave-m
    Re: WVD24460gb/02
    Hi Martin,
    Doesn’t count down and doesn’t spin, just sits there.
    After about 6/7 mins i switched it off and selected spin only and it spinded.
    d
    #387917
    Re: WVD24460gb/02
    One final thought……When it stops at the end is the correct spin speed setting lit (in rpm) or perhaps the no spin (tub) icon?
    #387918
    dave-m
    Re: WVD24460gb/02
    I’m afraid not, the 800rpm light was lit and the tub icon was off.
    D
