Hi guys, been out to this machine recently – checked all the stats all ok and not tripped. Wash element reading around 2Mohms so replaced with new one but still not heating water – completes cycle ok but washing in cold water only !!
Dryer not drying either – does not seem to be any voltage to the dryer element – have tested stats all ok !!
Do you think timer may have been damaged due to high resistance on element ??
Re: wvf2402gb/02 no water heating or dryer function
As far as no heat on t/dry is concerned then an o/c inlet valve can cause that fault. No heat on wash then perhaps the t/stat is the culprit? The prog timer on these pretty basic so I’m not sure these faults would lie there? But surprise me…. 😈
