ZAN D/W not filling
Viewing 15 posts - 1 through 15 (of 15 total)
  • #4896
    machineman
    Models de6544 zds 699 both models same fault– slacken fill hose relieve pressure away it goes, water chamber clear p/switch operating .couple off days later fault reappears no fill help
    #106019
    grooster
    Ive had this problem a few times now and by swapping the matrix down the left side of the cabinet seems to have cured them all so far. Its quite a fiddley job but its worked for me.
    good luck
    nick
    #106020
    bonzaco
    Maggi – If you can get hold of Alex he will talk you thro this problem. As stated one version of this machine needs the matrix to rectify the fault but the other version needs a syphon tube replacement. Ive had about 5 of these little bleeders over the last two weeks and Alex has saved the bacon on both versions. Regards – Bonz
    #106021
    machineman
    how do i get hold of alex bonza .maggie
    #106022
    By his goolies usually works 😆
    #106023
    bonzaco
    Sorry all I only managed to get hold of Alex last nite. He’s away until Tuesday but I will pm his phonenumber to you tomorrow.
    #106024
    Dave_Conway
    ted wrote:By his goolies usually works 😆
    That would be of the singular I think you’ll find 😯
    But according to rumour (the one Alex started himself), it’s a beauty 😆
    #106025
    renno
    Re: ZAN D/W not filling
    forget the iwms (matrix) get hold of any lux serviceforce center and go straight for the pressure switch replacement
    #106026
    renno
    sorry forgot state if its a 2or3 valve iwms
    #106027
    Tom
    zanussi dishwasher not filling
    bonzaco wrote:Maggi – If you can get hold of Alex he will talk you thro this problem. As stated one version of this machine needs the matrix to rectify the fault but the other version needs a syphon tube replacement. Ive had about 5 of these little bleeders over the last two weeks and Alex has saved the bacon on both versions. Regards – Bonz
    I am coming across this problem; a complete dismantle releiving any pent up pressure has provided a short term cure. I would like to hear the story from Alex if possible.
    Tom
    #106028
    Dave_Conway
    Re: zanussi dishwasher not filling
    Tom wrote:A complete dismantle releiving any pent up pressure has provided a short term cure.
    Is that you or the dishwasher Tom ? 😆
    #106029
    Alex
    I have p.m’d Tom.
    The best fix is a new IWMS, (Matrix) There is a valve kit and pressure switch mod kit as well, but the IWMS will still need doing. Valve kits depend on how many valves are on the IWMS.
    Any NESN agents should be able to ask Stoke for the details on the valve kits. Best of luck on that one.
    #106030
    Alex wrote:Any NESN agents should be able to ask Stoke for the details on the valve kits. Best of luck on that one.
    Oh you’re a baaaad man Alex! 😉
    nemo
    Alex wrote:I have p.m’d Tom.
    part no for valve kit 50271495009 ?
    comes complete with instructions. a doddle after the first 50. can only be fitted to version 2 I.W.M.S (the two solenoid one) and contrary to above if the I.W.M.S ain’t blocked leave it alone!
    #106032
    DentedPorsche
    Haven’t done very many of these but the few that I’ve done have all had blockages between the Matrix and sump. One or two have also had weak valves. To date have never needed to change the Matrix.
