Zan D/w ZT695 Not Filling
  • #9795
    laurenceuk
    I am going to this machine tomorrow. Customer thinks it was error code 3 but it is not filling. I am anticipating it to be the water tank.
    I have changed a tank in this type of d/washer in this village before and after about a year it clogged up again. I am concerned that because of maybe environmental factors, ie. water is aiding algee growth in tank ( not an expert here but the tank is always black along the inside of the bottom part of tank), that this may occur with this machine also and it will quickly clog up again.
    Is there expert advice that anyone can give as to wether this can be stopped from happening. I think he said it was only about 2 years old.
    Can you give me the part number for the unit, I am still waitng for my new TDS disc.
    Laurence
    #135872
    Re: Zan D/w ZT695 Not Filling
    1524624-03/6 Laurence – £51 list, a whole kit of goodies.
    Cheers,
    laurenceuk
    Thanks for your help Chris
    Laurence
    #135874
    laurenceuk
    The fault with this machine was not as I thought (blocked metering tank).
    The symptoms where the same ie. inlet valve humming but no fill. I stripped off the pressure system hoses and ensured there was no blockages, air locks etc but all seemed ok. Put everything back together and all worked well.
    That was last Thurs and have not heard anything back as yet so am assuming machine still working.
    What else may cause the pressure unit on the inlet valve operate?
    Laurence
    #135875
    martinatmull
    Hi Laurence
    If this fault re-occurs come back to me direct “martinsm@tiscali.co.uk” a mod may be needing fitted
    Martin :o)
    #135876
    laurenceuk
    Thanks Martin, will do :D.
    Still working as far as I know.
    Laurence
    #135877
    laurenceuk
    Hi Folks,
    This machine has worked for three weeks but now shows the same symptoms as the original fault (see first posting). The customer can hear the humming of the inlet valve but no water coming in.
    Although the tank looked very clear, is it possible that it could still be creating this problem?
    Martinatmull has provided me with some very usefull info (thx Martin). How does the volumetric control operate? And what does the reset valve do?
    Your responses are always gratefully received.
    Laurence
