hi guys d/washer no heat checked all the usual problem areas ?…
heater, ok!!..wiring loom at bottom of door(internal), ok, no broken wires,
d/w goes thru the complete cycle??.., faulty control unit??..
appreciate your input….
jasper.
This is a usual fault with these…check the back of the timer/module behind the facia panel….you will more than likely find the solder blown in the pcb where the relay goes….either repair or replace if that doesn’t work!
jazzmeister,and penguin45,
thanks for your input fault sorted!!!….customer delighted with the requote,
no!! control unit reuired eg;..r r p for said part apprx 100-00 quid plus.
another satisfied cust.
jasper.
