zan dw zsf6120 Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zan dw zsf6120 This topic has 4 replies, 3 voices, and was last updated 16 years, 1 month ago by adv. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts February 24, 2010 at 8:36 pm #52776 advParticipant this dw runs al day no heat, looks like pig to get into. do they get dry joints on pcb or more likely to be heater? or any other common reasons on this model. any tips guys cheers 😆 February 24, 2010 at 8:38 pm #313093 JazzmeisterParticipant Re: zan dw zsf6120 More than likely a dry joint on the heater relay…bit of flux and solder and your away! Jazz February 24, 2010 at 8:53 pm #313094 advParticipant Re: zan dw zsf6120 is it easy to spot ie like the bosch ones open plastic cassing to pcb an ther it is? 😆 February 24, 2010 at 9:29 pm #313095 FirestarterParticipant Re: zan dw zsf6120 yer similar to the bosch ones. If the board looks OK though it will be the tubular heater behind RH side panel. February 24, 2010 at 9:38 pm #313096 advParticipant Re: zan dw zsf6120 thanks lads Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
