Zan DW ZSF6150S…+ TDS Disc
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zan DW ZSF6150S…+ TDS Disc
  • #35739
    robbra
    Hi all
    PNC 911915083…no heat but element ok
    Have three left hand light flashing together. Intensive, auto and quick wash.
    Have looked on the disc but can’t find this as a fault diagnosis but always have a bit of trouble with this disc so can anyone throw any light on it?
    Rob
    #247854
    smeghead
    Re: Zan DW ZSF6150S…+ TDS Disc
    have had same fault, control unit ( dry joint on relay ) cant be sure of lights though. have you opened up pcb to check? my tds disc is playing up
    as well- perhaps they have a shelf life after all.
    #247855
    Flyman
    Fault code is indicated by a sequence of flashes of the End of Cycle light. It is not by the display lights. Count the number of flashes.
    1=time out fill
    2=time out drain
    3=anti flood
    5=motor triac short circuit
    6=overheating or heating time out
    7=ntc ope or short circuit
    8=communication error
    9=software problem
    11=turbidity sensor
    13=no signal from tacho
    15=water replenishment problem.
    #247856
    robbra
    Thanks lads,
    Looks like I’m going back to do a count and check out the board too.
    Rob 😳
