Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zan E40 not interlock
- This topic has 9 replies, 6 voices, and was last updated 17 years, 1 month ago by
pmb.
March 3, 2009 at 4:57 pm #43922
pmb
ParticipantHi i have a zanussi IZ16S which is showing e42 through the diagnostics. I have replaced interlock (4 times) and pcb. I have checked all the wiring from interlock which goes to the pcb, pressure swich and on/off switch. I nipped all the connections to make sure they are a tight fit. I checked for earth leaks too on heater and motor. Also i have tightened connections for display module but i still have this problem. The interlock does lock by the way but it continues clicking. Any help on this would be greatly appreciated :lesson:
Thanks PeterMarch 5, 2009 at 10:26 am #279082pmb
ParticipantRe: Zan E40 not interlock
Has no one else had this problem? There must be a genius from zanussi that can help, this machine is driving me crazy :bang:
Thanks PeterMarch 6, 2009 at 1:43 am #279083leavemetogetonwithit
Could door striker not be engaging fully with interlock? What happens when interlock operated manually?
Mike.March 6, 2009 at 8:54 am #279084pmb
Thanks Mike but i have tried operating it with a screwdriver but it is the same, it locks but then continues clicking and then shows e40. Does anyone know if zanussi has a technical support number?
March 6, 2009 at 1:38 pm #279085Martin
pmb wrote:Does anyone know if zanussi has a technical support number?
I don’t believe they have but if you have a chat with your local friendly Service Force dealer chances are they’d help you out. I have 3 such dealers in my patch and they have been very cooperative to me over the years. 🙂
Tip: Best to ring mid afternoon with queries as often as not one of their engineers is back in the office to advise. 😉
March 8, 2009 at 6:15 pm #279086Steven
Possible one of the pumps shorted out,usually the recirc, this can damage the triacs on the pcb. You say you have changed the pcb, check the individual triacs you may see one with a chip out of it, trace it back to the relevant pump.
You may have have damaged the new board.Hope this helps
Steven
March 8, 2009 at 7:01 pm #279087boselecta
ParticipantI recently changed an interlock when it was just clicking like this, when I investigated further turns out the carbon brushes were worn. Replaced them and it worked ok.
Check for earth leakages.March 9, 2009 at 8:41 am #279088pmb
Thanks alot everyone for all the advice i am going to get stuck in to this today 😀
March 11, 2009 at 4:51 pm #279089Tubs
Steven wrote:Possible one of the pumps shorted out,usually the recirc, this can damage the triacs on the pcb. You say you have changed the pcb, check the individual triacs you may see one with a chip out of it, trace it back to the relevant pump.
Steven
Have also had this and was re circ pump melted, had me scratching head for a while.
March 12, 2009 at 8:51 am #279090pmb
It was the wires on the connectors to pressure switch,
It was intermittent, so several times i thought i solved it.
Thanks everyone for your input -
