I have a problem with one of these that as soon as you switch it on, on any programe the pump just comes on all the time.
I have cleared the pressure chamber etc (Which was blocked) thinking that will sort the problem out, but is still does the same.
Could it be the anti foam pressure switch ?
Any help would be appreciated
Regards
The anti-flood feature of the pressure switch is connected in series with the drain pump? If the manifold and air tube are clear then the pressure switch is probably at fault?
