ZAN FJS1225W 914512720/00
  • #13292
    DAR01
    Customer washed bath mat ,OOPS (which broke up in machine).
    Cleared residue out of drum,pipes and expansion chamber.
    Machine fills with water, then motor goes into a partial spin.
    Checked motor/tacho seems OK.
    Last test reset to drain programme stopped on 1 minute,couldn’t open door.
    Any ideas anyone?
    Mike
    #154059
    Re: ZAN FJS1225W 914512720/00
    DAR01 wrote: ,couldn’t open door.
    Mike
    Is it one of those locks with a tube on? ➡ pressure sw chamber still has bit of bath mat in ❓
    #154060
    DAR01
    Newer type door sw no pipe.
    #154061
    DAR01
    Anyone know how to configure the Zan Module ,please.
    MIKE
    #154062
    mbdas
    Did the drain pump run ❓ I think it has a TOC in it poss more bath mat in it .Have you had the pcb out if so can you see if anything is blown on it
    I’ve had a few where the drain or recirculation pump has shorted and then blown the pcb.
    mark
    #154063
    fennyapps
    If you have TDS offline all the information is listed after you type in PNC no: at the bottom of screen. Diagnosis, configuration etc.
    Hope this helps
    Paul
    #154064
    DAR01
    No obvious damage to board, pumps out OK
    Mike
    #154065
    Dave_Conway
    Mike, if you’re on Broadband i can send a hefty 1.5mb pdf I have if it may help ?
    #154066
    DAR01 wrote:Machine fills with water, then motor goes into a partial spin.
    (This shouts tacho,doesn’t it?)
    (Even though.)
    tacho seems OK.
    Mike
    Edit 8.30am: Suggest wiggle all wiring between tacho and pcb then check again for correct resistance from where it joins timer. Most likely place is motor connector but could even be connection inside motor plug. (Trying to spin with water in could have stressed connections).
    #154067
    DAR01
    Got TDS now goig to customer this afternoon armed with a thick file and a deck chair.
    Thanks for all the info.
    MIKE
    #154068
    DAR01
    Replaced module ,working OK.
    Mike
