zan fjs1397
  • #13940
    tonyclifton
    Blocked
    only spins twice then stops checked brushes and seem to be good hanged in another motor same fault, is this gonna be timer shot
    #157254
    Re: zan fjs1397
    Could be worth sending timer to emw for testing/repair.
    Or they may have one in stock which you can try in for handling charge only (£4.70) if it turns out to be mis-diagnosis.
    emw 0115 9652118 or http://www.emwelec.co.uk
    Mike.
    #157255
    farmboy
    Re: zan fjs1397
    Timer doesnt have much to do with the spin on that model – all the speeds & direction control is done via the module, it may be worth checking the manifold/air chambers if you havent already done so. The one on the manifold is prone to blocking on this range and will cause spin problems.
