Zan FL1082 (91478955301)
  • #38107
    goosegreen
    Quite an old machine, But customer would like to keep it going. Fault is: Will go through wash till the last spin do the conditioner fill then click to off.
    have tried with machine filled and empty same fault. pressure system clear and can hear clicks from P/Switch, So presume the timers faulty but at over £100 I would want to be sure.
    Goose
    #257745
    Simon46
    Re: Zan FL1082 (91478955301)
    EMW 😀
    S.
    #257746
    aqualectric
    Could be a shorting armature, worn brushes, displaced tacho coil or timer. Usually armature / brushes. If you suspect timer, EMW do it; so it should still be a viable repair. 😉
    HTH,
    Steve.
    #257747
    goosegreen
    Thanks all, Any one know the link for EWM not showing on google?
    Goose
    #257748
    goosegreen wrote:Thanks all, Any one know the link for EWM not showing on google?
    Goose
    Thats because its EMW 😀
    http://www.emwelec.co.uk/
    goosegreen
    Cheers Jim, Late start today 🙂
    John
