Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zan FLE 1016W. Lights 1, 4 & 8
- This topic has 8 replies, 4 voices, and was last updated 14 years, 5 months ago by
happycack.
November 1, 2011 at 11:03 am #65992
happycack
ParticipantApologies if the answers on here but I can’t find it.
Machine has intermittent start after programming after door is locked and occasionally comes up with lights 1, 4 and 8 counting from top to bottom of the neon relating to the programme sequences. Any clues?November 1, 2011 at 2:33 pm #362653shaun67
ParticipantRe: Zan FLE 1016W. Lights 1, 4 & 8
I think the code is E91 ..
Shaun
November 1, 2011 at 4:09 pm #362654happycack
E82: Error in reading the RESET/OFF position of the programme selector.
E83: Error in reading the programme selector code
E93: Incorrect machine configuration.
Above is a section of all I can find on Zanussi.
What is E91? (or have I done too many today?)November 1, 2011 at 6:23 pm #362655shaun67
happycack wrote:E82: Error in reading the RESET/OFF position of the programme selector.
What is E91? (or have I done too many today?)Hi E91 is – Communications error between main PCB and display board.. check Wiring, main PCB , display board .
Shaun
November 1, 2011 at 7:50 pm #362656happycack
Sorry if I seem to be an ignoramus. Thanks Shaun; I shall return and check all that you have said.
P.N. Would be great if we could get these error codes in some form of order in this site. Like brand name titled or something so you don’t have to trawl through all of them until you find it. Not a nag, still a brilliant font of knowledge, just a thought.November 1, 2011 at 9:23 pm #362657iadom
ModeratorRe: Zan FLE 1016W. Lights 1, 4 & 8
Are you volunteering? 🙂
November 2, 2011 at 8:03 am #362658happycack
If I could I’d give it a shot. Took me five mins to type this!
November 2, 2011 at 9:23 pm #362659bigchrisoioi
deffo 91…its the blue cable between the power and display PCB…either replace it ot tweak the pins carefully to make tighter fit on the pcb’s….i always replace the cable and the jobs is good….ok, the lights are easy….the 8 lights are in 2 banks of 4…using binary logic, working from bottom the lights are as following 1,2,4,8 – 1,2,4,8….so add the numbers up on each bank of 4!!!…easy i hope or i have confused the hell out of u …configeration of 15 codes using this display can be fun lol
November 2, 2011 at 9:25 pm #362660bigchrisoioi
just to show how it looks, this is it on machine—
8
4
2
18
4
2
1 -
