Zan FLE 1416W
  • #17710
    PIP-pm-
    Hit the on/off button Power light comes on no wash selection is available and no error code lights no door lock light constant beep beep after 2 mins
    ASny body got any ideas cos it stumped me.
    Phill
    #175883
    Dave_Conway
    Re: Zan FLE 1416W
    Can you acccess the configuration/diagnostics ?
    Press the SKIP/RESET button to cancel the programme previously selected and switch off the appliance.
    Press the START/PAUSE button together with the SKIP/RESET button and then, holding down both buttons, press the ON/OFF button to switch on the appliance.
    Hold both buttons (START/PAUSE and SKIP/RESET) down until the buzzer sounds and the LEDs begin to flash (about 4 seconds).
    At this point, the display board is checked and the LEDs (and, if featured, the display window) light in sequence.
    If it won’t accept that then the control PCB is the culprit I would think…
    #175884
    PIP-pm-
    Re: Zan FLE 1416W
    Was the PCB took it off and the tell tale sign of it blown to bits gave it away.
    Phill
    #175885
    Re: Zan FLE 1416W
    What is going on in Swansea I wonder? Half naked women and feathers? 🙄
