Zan fx1465w
  • #45224
    megawatt
    Called out to m/c bleeping after about 45 mins from start. Found no drain due to sticking golf ball in sump hose. Removed ball, tested, billed and waved good bye. Called back for similar fault. At end of wash m/c will drain, shut down and then start to bleep. Is m/c remembering the old fault code? does it need to be reset? and how is it done?
    Any help gratefully received,
    Mike.
    #284094
    LJDomestics
    Re: Zan fx1465w
    I think we covered the ECO ball a day or so ago in another topic.. thats meant to be there.
    #284095
    megawatt
    Re: Zan fx1465w
    That is interesting. Do you think a missing eco ball would cause this problem?
    Mike.
    #284096
    LJDomestics
    Re: Zan fx1465w
    No…
    The ball should be replaced tbh.
    What made u think it was a golf ball? how do u think it managed to get in there?
    #284097
    Re: Zan fx1465w
    I think megawatt is mixing up golf and table tennis. I guess the balls look just the same from a spectators’ point of view 😆 .
    Mike.
    #284098
    megawatt
    Re: Zan fx1465w
    Yes, Megawatt is mixed up but not about golf balls. I know the purpose of the eco ball but have got accustomed to calling a golf ball due to a long story about a customer who played golf. Do any golfing fans know how to read the fault codes on this machine and what the fault codes are?
    Mike.
