Zan/Lux main PCB change
  • #54990
    Due to the cost I have never had to do one of these before but have a three year old AEG with blown doorlock that has taken out the main PCB.
    I can just about manage to manouver the PCB to take off the back cover and see the blown tracks.
    Is there a knack to getting these things out completely and back in, or is it a struggle, hardly room for my tiny mits in there. 😥
    #321637
    bigchrisoioi
    Re: Zan/Lux main PCB change
    cut all cable ties and plastic moulds on old pcb holding cables, and then pull upwards………its fiddly !!!!
    #321638
    ….and into the valley of death rode the…….
    #321639
    Re: Zan/Lux W/D main PCB change
    She has just rung back to give me the go ahead, don’t know if I should be pleased or not. 😉
    It does look a real pig of a job. :rolls:
    A total PITA! Can’t believe how few Lux jobs you have up there that you haven’t had to do this till now.
    Mike.
    #321641
    It seems as though an epidemic is starting. 😀
    Had five or six Lux group W/Dryers in past two days and had several with low insulation dryer elements in past few weeks.
    Fitting a motor to one tomorrow, couple of brush jobs today on Zan machines, all grist to the mill. 8)
    The locals are reluctant to pay for such expensive repairs as PCB’s normally but this one is a three year old integrated job so any replacement machine will be costly as well.
    Quick supplementary question re unconfigured boards. I have just had a quick look on TDS and can’t see any info on how to configure the PCB’s on these, am I missing something?
    Model is a 914601218/01..ZJD12191
    #321643
    TheSpinDoctor
    Hi.
    You can only configure the board via a program called sidekick which is as far as I know only available to Serviceforce techs.
    You can order a preconfigured board. Part number is: 973914601218014
    #321644
    Already got that on order and its £2 cheaper than the unconfigured board. :con:
    I was just curious thats all. 8)
    careful Jim, 2 of these I did also needed the display board, no obvious damage but no lights or functions when turned on.
    #321646
    robbo1973
    also had about 4 which have needed display board as previous poster has said but another 2 which also needed the analogic pressure switch as well!!!
    cheers chris
    #321647
    Warnings heeded. 😥
