zan oven zob551x 949712893
lady has had a temp prope in oven and says its 5 to 20 below wot it should be so not getting to the right temp , put a new stat in and she says its doing the same? any ideas
its a fan oven element working fine
dop
Thermostats have a tolerance of up to 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} either way, PT electronic ones are more exact. Best to get a K type thermister probe & check it for yourself, as I’ve found that the analogue test temp’ clocks sold in hardware stores to public are way off, that’s the one that hangs inside oven & viewable through the oven door.
