zan over fill
  • #32045
    dopper
    zan zwf1221w over filling, check p/hose ok blow into p/switch sounds ok could it b the pcb?
    paul
    #233408
    Re: zan over fill
    dopper wrote:blow into p/switch sounds ok
    Did that not stop it from filling then when you did that?
    #233409
    dopper
    Re: zan over fill
    no kept filling switch had to clicks
    #233410
    Re: zan over fill
    Module fault then I guess? 😕
    #233411
    cab
    Re: zan over fill
    hi I have had one recently that would over fill then drain. All it was was a wire off the element. The fault code said it could be down to earth also!
    cab
    #233412
    What kind of electronic has? (EWM2000; EWM1000Plus…)
    Inside service regim all works? without any alarm?
    #233413
    dopper
    Re: zan over fill
    spot on with the wire to heater, the plug was off, nice one
