zan tc7103 leak etc
  • #72424
    delta01
    hi this machine leaks and does not fill bottle, i suspect a pipe of but not sure how to access any help appreciated
    thanks john
    #384485
    martinm
    Re: zan tc7103 leak etc
    no pipes to worry about on these tank is at bottom gravity fed,
    ive only seen them leaking when the condenser is not pushed in and enggaged with clips properly, quite commom
    #384486
    captaincaveman1
    Check the valve that the tank pushe’s onto at the back hasn’t sprung apart
    #384487
    delta01
    thanks guys, how do i access the valve ?
    #384488
    captaincaveman1
    delta01 wrote:thanks guys, how do i access the valve ?
    Rmove the tank and tilt it backwards you will then see it and possibly a spring and the inner part of the valve will be sitting on the floor.
