Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zan TD dead
- This topic has 11 replies, 5 voices, and was last updated 18 years, 9 months ago by
abbots.
June 20, 2007 at 10:26 am #28300
abbots
ParticipantTCE7276W.
hi guys,
power supply ok,door switch ok.
the lights on the front come on but no motor action or heat or anything.
are the PCB’s problematic on this model?
is there something i’m missing here?
thanks,
johnJune 20, 2007 at 11:16 am #217738Martin
ParticipantRe: zan TD dead
abbots wrote:is there something i’m missing here?
Have you checked the safety switch on the condenser access panel?
….or the T/stat in the front drum housing?
June 20, 2007 at 12:23 pm #217739abbots
no i haven’t were are they situated?
johnJune 20, 2007 at 12:27 pm #217740Martin
abbots wrote:no i haven’t were are they situated?
johnPlease read my post again as I have told you where they are 😉
June 20, 2007 at 12:31 pm #217741abbots
oh very very sorry martin,
just didn’t quite ubder satand what you meant by access panel thats all
jkJune 20, 2007 at 1:51 pm #217742abbots
the microswitch behind the bottom right hand side of the plinth that indicates when the condensor flap is open is fine.
i cant seem to see a t/stat on the front of the drum,i cant see one listed on connections either,only a NTC temperature probe,will this be in the same place as the thermostat on the older condensor dryers i.e. near the top of the drum front.
If so how do you get to it to test it?when the lid is removed all you can see is a white plastic housing and the PCB cover.
does the front of the machine come off or do you have to remove the drum from the rear?
even the control panel seems a nightmare to get off, is there an easy way.?
when you swith the machine on all that happens is the “time to go” is dislayed and the start light flashes as if it’s ready to go ,but nothing happens when the start button is pressed,is there a matrix behind the switch that breaks, so the button doesn’t make contact with the switch?
any advise will be great.
thanks
johnJune 20, 2007 at 2:06 pm #217743ANDYVIVO
Hi John
It will be a broken “light diffuser” which is a frame for the buttons and lights, VERY common part. Correct PNC will get you the right one!
Regards AndyJune 20, 2007 at 2:09 pm #217744abbots
nice one Andy,
never heard of the part.
TCE7276W
916092667/00
Sn 43400181part number would be great
where is the part situated and how do i get to it?
thanks buddy.
johnJune 20, 2007 at 3:25 pm #217745ANDYVIVO
Hi John,
It is part number 1251185300 in stock @ Masterpart £4.20 +.
Located between the fascia panel and module, (it makes contact from the yellow button to the module), fascia off, then remove module WITH housing and all will be revealed. 😉
Regards AndyJune 20, 2007 at 3:30 pm #217746abbots
cheers andy
June 20, 2007 at 3:32 pm #217747wilf
yep light diffuser every time
wilf
June 20, 2007 at 4:48 pm #217748cab
did one today, common as .
cab
