Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › ZAN WJS1397
- This topic has 5 replies, 3 voices, and was last updated 21 years, 11 months ago by
machineman.
May 13, 2004 at 10:01 am #5503
machineman
ParticipantWierd one this,9times out of 10 it works,every now and then it fills and sits there no jet /no motor. turn it to spin, pumps out spins.turn back to wash prog works ok.it seems as ifthe jet pump doesnt kick in at low level fill when it does m/c works help.m
May 13, 2004 at 12:08 pm #111599Dave_Conway
ParticipantRe: ZAN WJS1397
Pressure switch maybe ?
I think on these that the 1st or 2nd level on the switch triggers the motor action and circulation pump, the water then continues to fill untill either the 3rd level is reached or the other smaller pressure switch turns the water off.
Or it could be the other way round, I can’t remeber exactly which order the levels are switched, but worth a look at I would think.
May 13, 2004 at 1:03 pm #111600Martin
machineman,
Also take the sumphose off the manifold just to check there’s nothing stuck in there? I have had 2 similar probs with same model kind of giving those symptoms. The first was a phonecard stuck in the pipe acting like a flap valve and the other job was a rubber adidas badge off someones trainers stuck in there!
Does the Timer start skipping along for no reason sometimes I wonder as well?
Start with the simple then start scratching your head and saying “Oh dear missis you got a problem there right enough, who one earth sold you this load of garbage?”
May 13, 2004 at 5:27 pm #111601machineman
Thanks for the replys guys cant see it being a blockage as there is no feed to jet pump, pressure switch seems likely, any idea which one controls that initial jet or better still a part number of offending switch Regards M
May 13, 2004 at 7:11 pm #111602Martin
machineman wrote:Thanks for the replys guys cant see it being a blockage as there is no feed to jet pump
That’s fine, but DO check for the possibility as both the ‘Wash Pump’ and Inlet Valve do a merry dance together in these circumstances. Do take a look for my benefit and tell me I’m wrong OK 😉
machineman wrote: pressure switch seems likely, any idea which one controls that initial jet or better still a part number of offending switch Regards M
The Safety Level Switch is 1247328907 and the 3 level is 1247328303. It may interest you to know that Wash Vacs (Part Center) list them as ‘Special Order Only’ which is a good indication that they don’t sell too many/if any to warrant stocking them!
May 31, 2004 at 7:47 pm #111603machineman
thanks martin/dave both spot on. pressure s/w not always switching due to a blockage in the pressure chamber thanks a lot machineman
