zan wm faulty
  • #60299
    abbots
    hi,
    FX1265W
    914792510/00
    machine switches on, door interlock activates.
    the machine will pump out for about 5 seconds and then stops dead.
    no fill or motor action on any programs.
    I.R. fine.
    carbons fine
    valves fine
    p/system fine
    any ideas?
    cheers.
    john
    #341674
    Re: zan wm faulty
    Posted in wrong forum John. 🙁
    But anyway it’s best you access ‘Diagnostics mode’ to suss out last error detected matey! 💡
    #341675
    abbots
    Re: zan wm faulty
    ok ta
    #341676
    Re: zan wm faulty
    And also check for insulation resistance below FORTY MEGOHMS on heater element as that will give you exactly those symptoms. IME, if it was just a bit of damp on the motor, your initial IR would have been a fail but that’s worth a check anyway, especially if m/c in shed.
    Mike.
