ZAN ZJD12191 Fills then stops
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries ZAN ZJD12191 Fills then stops
  • #57819
    pmb
    ZJD 12191. 91460121801
    If i put on wash it fills then after a couple of minutes it stops and start/pause
    flashes,
    I have checked heater, its ok. Spins OK
    I know i should do diagnostics check but i dont have it for this model.
    #332403
    Re: ZAN ZJD12191 Fills then stops
    pmb wrote:I know i should do diagnostics check but i dont have it for this model.
    Well if you hold a Connect a/c you can at least download it from their Mediator options if you wish.:wink:
    #332404
    Bernie
    Check you email
    #332405
    If it’s a washer/drier pay special attention to page 86.
    Mike.
    #332406
    pmb
    The pages only go up to 67. ❓
    #332407
    leavemetogetonwithit wrote:If it’s a washer/drier pay special attention to page 86.
    Mike refers to the old 118 page ‘general’ manual and not the 67 page EWM2000 series ‘test’ manual. In that one no doubt Mike would wish you to note the contents of page 49.:wink: 🙂
    #332408
    pmb
    Couldnt find it on connect,
    Forgot i had it on TDS Disc.
    Also Bernie Emailed it to me,Thanks,
    Did the Diagnostic,”E36″ Seems to be PCB, Told them to ring Zanussi
    #332409
    Seamy
    E36 is not always the board, it most likely will be the DRYER HEATER 1242658308 ,, disconnect all dryer heater cables & tape up securely. Try on wash cycle, you’ll more than likely find theres no E36 then. 💡
    #332410
    garn
    Had A Couple of These Over The year Same Fault everything Working Separately.
    The Sump Iv Found A Thin Layer of Washscumgrease Lining The Sump Filter
    Pulled It Of Throughly Cleaned It And Blew Air into The Pressure Switch And Its Up And Running.
    #332411
    Indeed.
    I can’t find a 67 page one 😕
    I just had got fed up repeating “40 Megohms” all the flippin’ time 😆 .
    Mike.
    #332412
    leavemetogetonwithit wrote:I can’t find a 67 page one 😕
    I’ll send you a copy Mike…check your email!:D
    #332413
    Thankyou for that, Martin. My education is proceeding apace.
    A snail’s pace.
    No, no I didn’t mean that last bit. Just joking. 😆
    Mike.
