Zan ZSF6120
  • #24618
    PGS
    Hi called out to the above dishwasher today, customer complaing no heat although m/c completes cycle. Checked heate with meter and supply voltage ok. Checked wiring continuity ok. I reckon on PCB as there is nothing between pcb and heater (stat). But a second opininon would be appreciated Cheers Paul.
    #202679
    Tubs
    Re: Zan ZSF6120
    Hi Paul
    Check PCB for dry joints on heater supply may look o.k but worth running your iron over just to be sure
    Steve
    #202680
    happycack
    Re: Zan ZSF6120
    Thanks Steve.
    Will let you know.
    P
    #202681
    PGS
    Re: Zan ZSF6120
    new board fitted m/c now Aok thankyou
    #202682
    MrTwintub
    I was at one of these machines this week, the customer had ignored a slight burning smell for the last month or so. The pcb and edge connectors are now badly burnt. I have ordered the pcb but Zanussi are telling me that the edge connectors are not available and I will have to buy a wiring loom 🙁 Anyone know Different?
    Cheers
    Andy
    #202683
    rogue_element
    Re: Zan ZSF6120
    hi please dont use a soildering iron on pcb`s. always replace
    yes will have to replace loom
    #202684
    clivejameson
    Re: Zan ZSF6120
    NLSERVICES wrote:hi please dont use a soildering iron on pcb`s. always replace
    But in the real world yes do use a soldering iron for a perfectly acceptable and reliable repair 😉
    #202685
    helo_75
    Re: Zan ZSF6120
    ah well, soldered joints can be better than them edge connectors.. for sure i seen a zanussi dw set on fire cos of dodgy edge connectors…
    manufacturers would tell u to change the loom wouldnt they
    and .. can i ask are u actully nl servces, or just using their name?
