THIS FAULT IS CAUSED BY A SOFTWARE BUG ON THE PCB, CHECK THE BOOT VERS ON THE WHITE LABEL ON THE PCB IF IT ENDS IN (09) IT CAN BE REPROGRAMMED BY SERVICEFORCE WITH “SIDEKICK” IF THE BOOT VERS IS 08,07 ETC YOU NEED TO FIT A NEW PCB.
IF YOU GO INTO DIAGNOSTICS AND CLEAR THE LAST FAULT ALARM IT WILL SOLVE THE PROBLEM BUT IT MAY COME BACK IF THE BUG IS NOT RESOLVED
